Run a count down or count up timer and display in OBS, on a Stream Deck, or check elapsed/remaining time via Chat Command. Timer works for Twitch, YouTube, and Kick
timer_v0.2.4.sb (20.9 KB)
- Download the .sb file
- In Streamer.bot in select
Importfrom the top left. - Find the sb file you downloaded and drag and drop into the
Import Stringbox of the Import dialog
Imported commands are disabled by default as a security measure. Review each command’s permissions before enabling each one.
In OBS
- Add a scene called
[NS] Timer - In the scene
[NS] Timer, add a Text Source called[TS] Timer
You can add the scene [NS] Timer as a source in any scene you want to display the timer.
Settings
Settings are located in the Timer Settings action.
| OBS Settings | Default Value | Description |
timerCountdownObsConnection |
0 |
The index of your OBS connection you will use for displaying the timer in OBS |
timerCountdownScene |
[NS] Timer |
Match the name of the nested scene created to display the timer text source |
timerCountdownSource |
[TS] Timer |
Match the name of the text source created to display the timer |
| Chat Settings | Default Value | Description |
sendAsBot |
True |
Any actions using the SendMessageToPlatformAction method will use this to decide to send a message as the bot account or not |
sendAllPlatforms |
True |
Any actions using the SendMessageToPlatformAction method will use this to send a message to all platforms that have used the timer actions (Twitch, YouTube, Trovo) |
| (Optional) Stream Deck Settings | Default Value | Description |
streamDeckTimer |
False |
Set to true if you want to update a Stream Deck button with the remaining time in the timer |
streamDeckButtonId |
`` | Set to the button ID of your Stream Deck button. You can get this by going to your Stream Deck application, creating a Streamer.bot Action button, and clicking the copy icon next to the Button ID. |
- If you want to be able to start the timer from the Stream Deck Button, assign the action to the
Timer Startaction, then add an argument with settings:
| Type | Name | Value |
| String | value | Number of minutes to set the timer to start |
Other actions with configuration
These settings apply to these actions: Timer Cancel, Timer Pause, and Timer Done
- Under Chat Settings, set argument
messageto what you want to send to chat - Under OBS, set argument
obsTextto what you want to display in the OBS Text Source
| Command | Action | Usage | Explanation |
| !timer | Timer Configuration and Start | !timer duration |
Makes timer visible and starts the timer to the number specified in the command. You can use !timer -0.02 if you want the timer to count up. |
| !timeradd | TimerAdd X Minutes | !timeradd duration |
Adds your desired number of minutes to the timer. |
| !timercancel | Timer Cancel | !timercancel |
Stops the timer, then hides the text source. Must type it in twice to confirm. |
| !timerpause | Timer Pause | !timerpause |
Pause the timer |
| !timerresume | Timer Resume | !timerresume |
Resume the timer |
| !timerelapsed | Timer Check Elapsed | !timerelapsed |
This will display the elapsed time in Twitch chat |
| !timerremaining | Timer Check Remaining | !timerremaining |
This will display the remaining time in Twitch chat |
| !timershow | Timer Countdown Action Group Enable | !timershow |
This will make the text source visible in OBS |
| !timerhide | Timer Countdown Action Group Disable | !timerhide |
This will make the text source hidden in OBS |
Duration can use the following syntax:
d for days, h for hours, m for minutes, s for seconds
Examples: 5d4h3m, 1h30m, 5m, 1h
1h30m or 90m should also work as equivalents.
A timer value set to up will initiate a count up timer instead of countdown. Which then needs to be cancelled manually.
