Control your OBS volume through Streamer.bot.
OBS WS v4.9
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
Set the Source Name in the first `Set Argument" subaction.
Uses a āget volumeā request to get the sourceās current volume and stores it in the variable āobsRaw.volumeā
- Then increments the variable by some amount (positive to make it louder, negative to make it quieter. Do some experiments to decide how big this number should be by monitoring sources and checking the difference. (edit: keep this value very small - too large and it will break the action. The import defaults to 0.1)
- (you can also use this to set the volume to a fixed value by unchecking the increment and setting the value to the one you want)
- Then uses a āset volumeā request to set the volume to the new value of āobsRaw.volumeā
