Simple Uptime Command
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
Once you’ve imported the code all you need to do is tie a command to the imported action. If you are offline, no message should appear however should you wish to create something in this case in the if statement change the do nothing to the action you wish to happen.
C# Uptime Code
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
Once imported you will have imported a !uptime commands too, so if you have a duplicate you will need to delete, disable or change one of them if you don’t want a 2 actions to run at the same time. The references should of imported with the code but if not, you will need to add
system.Linq.dll
If all that is done then your uptime command should be set-up you will just need to edit the output message to your specifications.
By design this is built to not output anything if the broadcaster is offline, if you wish to have something happen notes have been added to the C#, but if you don’t know what you are doing ask in discord for support. Edit codes at your own risk.
Configurarion
In the output message you can put the following variables and for 1 hour 30 mins and 20 secs they will output as follows
%uptime.secs%= 20%uptime.mins%= 30%uptime.hours%= 1%uptime.days%= 0%uptime.totalsecs%= 5420%uptime.totalmins%= 90%uptime.totalhours%= 1%uptime.totaldays%= 0
So just edit a Twitch Send Message Sub-action so it Outputs how you wish.
