Tool to Set a Cooldown Amount
Using this extension you can set global and user cooldowns through chat commands.
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
Ensure that the C# Code that has been Imported Compiles, if it does not you will need to add the following References:
System.dll
System.Core.dll
The Final thing you will need to do is create a Command, I would recommend at least with Mod Permissons, you can call this command what you wish but !setCooldown seemed good, and link it to the newly imported action.
Example Usage
!setCooldown <target> <command> <time>
target is global, user or both depending on which cooldown you wish to set.
command is the command.
time is the how long you wish the cooldown to now be.
If your command location is set to
Anywherethen you may trigger this or the cooldown action when using this.
{.is-warning}
Tool to Remove The Current Cooldown
This extension will remove both User and Global Cooldowns on the action you tell it to so it can be redeemed again.
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
System.dll
System.Core.dll
The Final thing you will need to do is create a Command, I would recommend at least with Mod Permissons, you can call this command what you wish but !removeCooldown seemed good, and link it to the newly imported action.
Example Usage
!removeCooldown <command>
{.is-warning}
Add User Cooldowns to Channel Points
This code will allow you to add user cooldowns to channel points so the same person cannot redeem the same reward.
Note, the redeem will still be triggered but if its under cooldown nothing will happen and the user will just be refunded. {.is-info}
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
This code will auto refund any action that is still in cooldown. {.is-info}
