This will allow your users to gamble there points for a spin on the slot machine, you can customize the emotes used, amount of emotes, pay out and default bet amount!
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
When importing you should have 3 actions
Slot Array Set-up
Slots
AddRemoveEmote
You will need the following references to ensure the code compiles.
mscorelib.dll
System.Linq.dll
You will need to add the following Commands
!slotemote = Tied to AddRemoveEmote (broadcaster)
!slotsetup = Tied to Slot Array Set-up (broadcaster)
!slot,!slots = Tied to Slots (everyone)
Then you will need to do !slotsetup to create the list of emotes, this action is a one time use.
You can use !slotemote followed by add or removeand the emote name to Add or Remove Emotes
!slotemote add Kappa
!slotemote remove Kappa
numOfEmotes This is the amount of emotes you want to be avaliable (minus 1)
defaultBet This is the amount the bet will be if the user doesnt specify
winMulti This is the amount the user will win of there bet multiplied.
