Simple Scrolling Credits
Example of credits in Streamer.bot using a simple scrolling style that allows for easy font and color changes in an editor as well as including intro and outro text/images.
Note: Original code for these credits were taken from a Codepen fork where it’s true original author could not be ascertained
Included:
  • Zipped folder with HTML, JS and CSS files
  • Video describing steps involved in adding, editing and styling credits
  • Notes to addressed updated features post-video released
Files
credits-simple-scrolling.zip (2.9 KB)
Download the files needed by clicking the link above and extract the folder to where you save your files used in your stream
Add a browser source to OBS and tick the “Local File” box and then browse to the folder you just extracted. Point to the index.html file.
Editing/Styling
The credits are styled using the included CSS (styles.css) file. While some of the more advanced changes will take a basic understanding of web development changing the two colors and (to a certain degree) the fonts are not complicated things to do. You will need a text editor. If you are working with an unaltered style.css you fill find the following sections on the listed line of the editor:
  • Font Class Import (Google Font) ---- Line 1
  • Font Name and Size ------------------- Line 21
  • RGB Color Code For Names Listed – Line 24
  • RGB Color Code for Titles/Sections – Line 37
Video
Video Notes/Updates
Since the release of this video some things have been added to the JS page, allowing for adding text and/or image URLs to the start and/or end of the credits as they scroll. You will find where to add them in the script.js file, lines 71-79.
