Searchable Quotes
Remember some words from a quote, but don’t remember what number it was? Search your quotes! These quote commands support a few extra ways to retrieve quotes, including search terms, phrases, position from the end of the list, as well as keeping the old reliable methods of retrieving quotes by their number, or randomly.
You can also chose between using Streamer.bot’s built in stable quote Ids, which don’t change if you delete a quote in the middle of the list, or a sequential quote numbering mode, which automatically fill the gaps in quote numbers that removed quotes would otherwise leave behind.
Requires Streamer.bot 1.0.0+ for the new quote Sub-Actions and methods.
searchable_quotes_1-3-1.sb (16.0 KB)
Quote Numbering Modes
There are two options for quote numbering, “Stable” and “Sequential” The default is “Stable”
Stable Quote Numbering
This mode is the default, and directly maps to the ID in Services > Quotes.
The advantage of this is that if you delete quote #3, quote #4 does not change, however, quote #3 remains a nonexistent quote unless you manually re-index your quotes.
You can manually re-index your quotes via the context menu in Services > Quotes.
Sequential Quote Numbering
Since there is no way to automatically re-index quotes, you can optionally switch to the Sequential numbering mode to emulate this behaviour.
In this mode, when you delete quote #3, quote #4 immediately moves up to take its place, avoiding any gaps between quote numbers. This transformation is non-destructive, and switching back to “Stable” numbering mode will revert to using their original quote ID
You can switch between quote numbering modes at any point by testing the “Test” trigger in the Setup and Code action or by running !quoteMode as the broadcaster.
Show Images
Responses
If you would like to change the text or behaviour of any of the error cases, it is handled in via the cases in Quote Display’s Sub-Actions:
Show Details
Some alternative groups are already provided, simply change which ones are enabled. Otherwise replace them with whatever you’d like.
Some variables will be set depending on what the search outcome was, and can be used in the output messages.
Show Variables
Variable Name Contains Available in Outcomes
%quoteDisplayNumber% The quote’s display number
(Accurate for both modes)
Success
QuoteIdOutOfRange (Last Quote #)
NegativeQuoteIdOutOfRange (First Quote #)
%selectedQuoteId% The ID of the returned quote Success
%firstQuoteId% The ID of the first quote Always
%lastQuoteId% The ID of the last quote Always
%quoteCount% The total number of quotes Always
The following commands are not case sensitive, capitalization is for clarity.
Command Description
!quote term Get a random quote that contains “term”
!quote term1 term2 Get a random quote with all terms
Especially useful if you saved quotes with a user attributed
!quote "search phrase" Treats quoted text as a single search term
Can be combined with regular terms
e.g. !quote "the answer" douglas
!quote -1 Returns the last quote, (-2 for the second to last, etc.)
!quote 3 Gets quote number 3 (obeying quote numbering mode)
!quote Gets random quote
!quoteDel 42
!delQuote 42
Deletes quote number 42 (obeying quote numbering mode)
!addQuote quote text
!quoteAdd quote text
Adds new quote
!quoteMode Displays current quote numbering mode
!quoteMode stable Sets current quote numbering mode to “Stable”
!quoteMode sequential Sets current quote numbering mode to “Sequential”
Default Command Permissions
Quote Display commands can be run by anyone
Quote Add and Quote Delete commands can be run by moderators
Quote Numbering Mode commands can be run only by broadcaster
Version 1.2.1
  • changed Action and Command group names from Quotes to Searchable Quotes
Version 1.3.0
  • Added FileWrittenTime metadata check on quotes.dat file in order to detect a manual re-index
Version 1.3.1
  • Fixed a bug which could cause an infinite loop if a quote was null
    • This state was only reachable with a quotes.dat file which was edited/generated outside of Streamer.bot.
Absolutely outstanding. thank you for this gift.
I’m having a strange issue with this. When I use any of these commands after importing, the log file starts counting to quote numbers in the hundreds of thousands looking for quotes (I only have just over 2000) and it doesn’t post anything to chat until I close streamerbot enitely and then it just fails to find anything. !addquote is the only one that seems to work.
We already talked, but for the record, this bug is fixed. It was only possible to reach by converting quotes from another source with external tooling, which could create entries where the quote text was null.
This extension will now clean up null quote entries if it encounters them, as of 1.3.1
Thanks for reporting this!
These commands aren’t working for me when I try to enter them on my Twitch channel’s chat. I did enable the commands after importing them, and I also would like the permissions for adding a quote to be set to everybody. Could you please help me with this?
you can edit command permissions the same way as with any other command, go to the Commands tab on the left and edit the command. you’ll see the permissions on the right side of the edit dialogue. if you’re having other issues, create a support post in the streamer.bot discord and tag me so you can share screenshots and logs if needed
