In Streamer.bot 0.2.1+ This has been built in as a trigger so is no longer needed.
This extension requires SB 0.1.14 to work. However there is a 0.1.12 Version at the bottom this wll be more like the example in the video.
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
Next thing to do is it tie the Action SceneSwitch to the swapping scene event in OBS which is different depending if you are using Websocket 4.9x or Websocket 5.
If you use Websocket 4.9x you will need to set up the OBS event like in the video it should look like this. You will tie the SwitchScenes OBS Event.
If you are using Websocket 5 you will need to set up the OBS event not like in the video, instead you will use the Event CurrentProgramSceneChanged
After then you will need to create an actions that are named identically to your scenes. This will mean when you switch to a scene Streamer.bot will try run an action of the same name. If you switch to a scene called Just Chatting then Steamer.bot will try look for an action called Just Chatting if it exists it will run it. If the action doesn’t exist it will run the action called SceneDefault. If you don’t want a default action to happen this action can be deleted or disabled.
The same effect can be achieved in UI with if statements as explained here https://wiki.streamer.bot/en/Broadcasters/OBS/Events/Scene-Events/CurrentProgramSceneChanged
Extended Feature
0.1.12 or lower Version
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
