Balanced Viewer Queue (BVQ)
A queue management and team balancing extension for Rocket League streamers who run viewer private matches. Players join a FIFO queue, and when you’re ready to play, the bot automatically pulls the next batch and splits them into MMR-balanced teams.
Features
FIFO queue — join order determines who plays, no favoritism
Automatic MMR lookup — fetches Ranked Doubles 2v2 peak MMR from Tracker Network on registration
Epic account validation — registration verifies the player’s Epic ID exists before accepting
MMR-balanced teams — brute-force optimal team split that minimizes MMR difference
Automatic rotation — finished players go to the back of the queue, next batch gets pulled
Self-report fallback — players can join with a rank (
!join C3) if MMR lookup fails -
Flexible format — supports 2v2, 3v3, and 4v4
Persistent data — player registrations, queue state, and match history survive restarts
In Streamer.bot, click Import in the top menu
Drag the
bvq.sbfile into the Import String field (or paste the import string) -
Click Import — this creates the BVQ Engine action and all 12 commands automatically
That’s it! Type
!queue openin your chat to start
Viewer Commands
| !register <EpicID> | Register your Epic Games display name |
| !join | Join the queue |
| !join <rank> | Join with self-reported rank (e.g. !join C3) |
| !leave | Leave the queue |
| !pos | Check your position in the queue |
Mod / Broadcaster Commands
| !queue open | Open the queue for joins |
| !queue close | Close the queue |
| !queue clear | Close and clear the entire queue |
| !queue list | Show current queue in chat |
| !balance | Pull next batch from queue and create balanced teams |
| !next | Rotate current players out, pull next batch, balance |
| !reroll | Re-shuffle teams (same players, new split) |
| !format <2v2\|3v3\|4v4> | Set the match format |
| !kick <username> | Remove a player from the queue |
| !mmr <username> | Look up a player’s MMR |
| !setmmr <username> <mmr> | Manually override a player’s MMR |
How It Works
Viewers register once with
!register TheirEpicName— the bot validates their Epic account against Tracker Network and saves their MMR -
Streamer opens the queue with
!queue open -
Viewers join with
!join— they’re added to the back of the queue -
Streamer creates teams with
!balance— the bot pulls the next batch of players from the top of the queue, resolves everyone’s MMR, and splits them into optimally balanced teams -
After the match, type
!nextto rotate the current players to the back and pull the next batch -
Want different teams? Type
!rerollto reshuffle the same players into a new split
MMR Resolution
MMR is resolved automatically in this priority:
Cache — if looked up in the last 24 hours, uses the cached value
Tracker Network — fetches Ranked Doubles 2v2 peak rating
Self-reported — if a player joined with a rank (
!join C3), uses that -
Default — 800 MMR (roughly Platinum)
Supported Rank Labels
bronze, silver, gold, plat, diamond, champ, gc, ssl
With tiers: b1-b3, s1-s3, g1-g3, p1-p3, d1-d3, c1-c3, gc1-gc3
Data Storage
All data is stored as JSON files in %APPDATA%/BVQ/:
players.json— registered players and their MMR -
queue.json— current queue state -
matches.json— match history (last 100) -
mmr_cache.json— MMR cache (24h TTL) -
settings.json— format and queue settings
To reset everything, delete the %APPDATA%/BVQ/ folder.
