Allow your viewers to enter raffles to try and win some big rewards, this has plenty of customization options to give you total control!
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
You will need the following references in order to get the code to compile.
mscorlib.dll
You will need to set up the following commands.
!raffle = Tied to Raffle Start
!join = Tied to Raffle Join
You can use this with timed actions if you wish, it will just use the defaultprize as the payout!
You may want to enable the command !join on starting a raffle and then disable it on a raffle ending.
Raffle Start
defaultprize This is the default prize if one isnt specified.
length This is how long the raffle will last for in seconds.
trigger This is the command people will use to join the raffle.
raffleCost This is how many points it will cost to enter the raffle, set it to 0 if you want it to be free.
Raffle End
multiWinners This controls how many people you want to win per ‘X’ amount of entrants. Setting it at 10 would mean if 10 people entered you would get 1 winner but 11 would give 2 winners. All winners win the same amount set via prize
