This extension will allow you to reset your points all back to zero if you so wish.
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
You will need the following references in order to get the code to compile.
mscorlib.dll
Microsoft.VisualBasic.dll
Newtonsoft.Json.dll
You will also need to create the following command.
!resetPoints = Tied to NewResetPoints
!resetVariable = Tied to UserVariableResetter
Example Usage
!resetPoints
>>Output = Points have been reset.
!resetVariable Tokens
>>Output = Tokens have been reset.
Remember when using the !resetVariable command that it may need to case match, it may work either way but it’s better to be safe. Please note for best results press Save before running this action.
