In the new version of the Streamer bot, the “events” tab no longer exists. Does something else have to be done now?
See the first FAQ here: FAQ | Streamer.bot Docs
Triggers → Twitch → General → Present Viewers
thx for the fast reply ![]()
hi thanks for this project, I have a question, how do I know how long the user has been looking with his username? Is there a file where all the data is saved?
Hello,
Thank you for this!!
Quick question, if i would want to set the watch time for some users that i’m importing from another bot. How would i do that? i’m not sure which Variable to use? is it PVminutes?
Thanks
This extension was coded to store into the variable %watchtime% in seconds. So make sure whatever you are importing is converted over to seconds and you should be fine.
Hey there, thank you for the extension. Would it be possible to use it on youtube aswell with minor changes?
Sorry just a quick question - does this pull the watchtime info from the first day the user has been following you or does it just start counting when the watchtime action is set up? If that is the case, is there a way to get that data and import it for a more accurate watch time for viewers?
Where do I find this? I checked the global variables and there is nothing there. I want to be able to reset watchtime at will. Is this possible? What about checking the watchtime in list format for all users?
