Minigame: Bank Heist
:money_bag: Streamer.bot Minigame: Bank Heist
A fully automated, dynamic minigame for Streamer.bot (Twitch). Viewers can form a heist crew by betting channel points and attempt to rob a bank together. The system supports flexible survival chances based on user roles (Broadcaster, Mod, VIP, User), dynamic timer controls, and multiple outcome scenarios.
Default language is German in this bot. But you can change it in the setup.
:hammer_and_wrench: System Architecture & Workflow
The minigame operates on a **3-phase logic**:
1. **Lobby Phase (Join):**
  • A user initiates the heist with “!heist”.
  • The script saves the start time as an ISO-8601 timestamp and enables the “Join Timer”.
  • Other users can join the heist crew within the entry window (heistJoinTime) using !heist < bet >.
2. **Execution Phase:**
  • When the “Join Timer” expires, Streamer.bot triggers the “ExecuteHeist()” entry point.
  • Each crew member rolls individually against their role-based survival chance.
  • Chat outcome messages are chosen based on success (Full Success, Partial Success, Total Failure).
3. **Cooldown Phase:**
  • After the heist, the bank enters a lockout period (heistCooldown).
  • The “Cooldown Timer” is started.
  • Once elapsed, “ResetCooldown()” clears the lockout **and sends a chat reminder (heistMsgReminder)** announcing that the bank can be raided again.
minigame_bankheist.sb (18.4 KB)
No extra resources are needed. All within streamer.bot.
First Step
In Streamer.bot click the Import button in the top menu. Drag the **.sb** file into the Import String field.
Second Step
Initial all Settigs and Timers (default is German).
Via Chat
Execute the following command in your Twitch chat as the Broadcaster or a Moderator:
!raub status setup
Via Trigger - Core > Test
Also a Trigger is in the Action [MINIGAME] [Bankheist] Code - Main with the argument Name: status Value: setup to run the setup.
First Step
Copy the Timer IDs by right-clicking each timer (Copy ID) into the 2 variables (heistJoinTimerId, heistCooldownTimerId)
  • [MINIGAME] [Bankheist] Timer - Join
  • [MINIGAME] [Bankheist] Timer - Cooldown
Second Step
Configure all Variables as you wish inside these actions.
[MINIGAME] [Bankheist] Settings - Config → heistPointsVariable : If you use “[Currency] Core System” you need to set this to “points”.
Also you can change the Command for the heist in Commands (default is !raub)
Third Step
Reconfigure all Variables as mention in Installation → Second Step
Command Description
!raub status setup To starting the setup initial (Only as Broadcaster/Mod)
!raub 2000 To join a heist with 2000 Points (must be between heistMinBet and heistMaxBet)
!raub status To get the actual status of the heist or Cooldown
This is the only command !raub that you need to configure. All others are managed in the C# Code.
:clipboard: Variables & Arguments Overview
1. Global Configuration Variables (`Persisted Globals`)
Action: [MINIGAME] [Bankheist] Settings - Config
These values are stored permanently (Global Variables) in Streamer.bot to control the game rules:
Variable Default Value Description
heistPointsVariable “userPoints” Name of the points variable in Twitch user database.
heistDefaultPoints 1000 Starting balance for new users without a points record.
heistMinBet 50 Minimum bet amount per robber.
heistMaxBet 10000 Maximum bet amount per robber.
heistMinParticipants 1 Minimum required participants to start.
heistWinMultiplier “1.8” Payout multiplier for surviving robbers.
heistJoinTime 60 Duration of the join lobby in seconds.
heistCooldown 300 Bank lockout period after a heist in seconds.
heistJoinTimerId “” The GUID of the Join Timer from Streamer.bot.
heistCooldownTimerId “” The GUID of the Cooldown Timer from Streamer.bot.
heistChanceBroadcaster 95 Survival chance for the streamer (in %).
heistChanceMod 80 Survival chance for moderators (in %).
heistChanceVip 70 Survival chance for VIPs (in %).
heistChanceUser 50 Survival chance for regular viewers (in %).
Also you can change and define it in the action
2. Chat & Language Templates (heistMsg…)
Action: [MINIGAME] [Bankheist] Settings - Language
Supports placeholders such as %user%, %command%, %remainingTime%, %amount%, %survivors%, %caught%, %payout%, %min%, %max%:
Variable Trigger Event / Function
heistMsgStart Lobby announcement when the first user runs !heist.
heistMsgJoined Confirmation message for joining robbers.
heistMsgReminder Announcement sent when cooldown ends & bank opens again.
heistMsgNotEnoughPoints Error message when a user lacks required points.
heistMsgInvalidBet Error message for bets outside allowed min/max boundaries.
heistMsgCooldown Notice when trying to start a heist during lockout.
heistMsgAlreadyIn Notice when a user attempts to join multiple times.
heistMsgNotEnoughPlayers Cancellation message if minimum participants aren’t met.
heistMsgProgress Message sent when entering the vault.
heistMsgSuccess Chat message when all robbers escape successfully.
heistMsgPartial Chat message when some get caught & others escape.
heistMsgFailed Chat message when all robbers are busted.
heistMsgStatusActive Response to !heist status during an active lobby.
heistMsgStatusCooldown Response to !heist status during the cooldown period.
heistMsgStatusIdle Response to !heist status when game is idle (includes %min%-%max%).
heistMsgNobodySurvivors Variable within (Success/Partial/Failed)
heistMsgNobodyCaught Variable within (Success/Partial/Failed)
Also you can change and define it in the action for diffrent language (default is german)
3. Dynamic Runtime Variables (Internal)
Managed automatically by the script during execution:
Variable Function
heist_active (bool) Indicates whether a join lobby is currently open.
heist_cooldown_active (bool) Indicates whether the bank is currently locked out.
heist_participants (Dictionary) Stores crew data formatted as “userId|userName|betAmount”.
heist_start_time_iso (string) ISO-8601 start timestamp for exact %remainingTime% calculations.
heist_last_run_iso (string) ISO-8601 completion timestamp for cooldown checks & self-healing
heist_used_command (string) Stores the primary chat command used (e.g., !heist or !raub)
Testing Log
Version 1
Running now multiple Days stable.
