Mario Clicker (Heat Map)
A Cool Mario Effect that is clickable with heat, it will also give your viewers a life every x amount of clicks.
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
Assets
Download the Assets here, extract them and put it somewhere safe.
interactive-super-mario.zip (48.0 KB)
Here is the codepen Version https://codepen.io/terrierdarts/pen/ZErVvXV
Here is the Original Pen by MercheDev https://codepen.io/merchedev/pen/BaYqyNx. Thank You for the work.
Once you’ve imported the code and downloaded the assets you will need to add a browser source in OBS called Mario-Click. (This will be the index.html file found in the dist folder that has been extracted.
marioclick
Then in The Heat Sources Logic you will need to add actions that get the properties of the source it should look like this.
You will then need to add the 1up Gif to OBS if you wish to have it.
Then finally tie all the Sub-Actions inside the Mario1Up Action to the correct sources and sound file.
The Set Argument Sub action in Mario-Click that value is of many coins equals a life.
REMEMBER if it says Someone has gained a life this is because that user has not given heat access to their user ID.
If you use a different websocket port that is different from the default one this will need editing in the script file.
