Check and see if Speaker.bot is running and if not, launch it.
TlM0RR+LCAAAAAAABACtV1tzolgQft+q/Q9WXndIHUASmap5iGZEjTEjKrd1HjgXgXi4LBcNTs1/3wZMoibOzuxuqqhId9Onv6+/c2i+/f5bq3WxYWkWxNHFx5b0oTZEbsjg7mLsFhHx59sgJ/4sYe6apRdNhEtyeCKDoD+r+1brW/MPXAGtHr1qi6trWaQCYaoitJVrIqgIS4Kqog5ZrWRJlsQmV/3QXwUrqiWjgvNXK4tczFmVL08LdmB/IrygrJ/G4SDI8jgtIWTl8uwg5h8x1FFeGhdJFXYuwOVbt8z0Inq7QupGNA5vaibeekkckSJNWZS/9b1h74jBOmTj8pqQixnLW7nPWitgppW4uf+hFUQV/CDyagd7Yq08bh0BgJDa56ZeEUIJLcx4vH2Fta+Qx2m1xIm9aeCKXK2ohERBxBIT2isJCR1ZRgK5UhRXxKLSFtnJg1sWeH4FF12iY09eJhUYESH12PHCP8DMAVF2kvKMApo6I8qeqtVerd8/nOczDapUk70s8kO6vgCtJwu/8J+xXAhPkbpFHs8bTMetPSBQdZnEVqIsyKIqCm0GVLpiBwkylRUmybitdMRfJlCS/3/+xJ/h73k7neSnLCNpkOy3wKl3zVhyw4PNGZ5StmKwQQg72Qm1s/dxuTShxHibLZf3AUnjLF7ll5PP8+Wyn0I12zhdX7WXy037El3KCFheLsOMxCkP8CXl/LiWf5txVmY5C+t8h+m+HiPBZc56Ma0ZotYkwSHxFjLfUc3IH7bo7tQ2XuuJbdICyxPkmpPd+zH8S2W/nSZbao4y17z3bOnJJ/K9NxW7w5mpgE3h4L++ncYjMjACrPHHoTbaYGnr6ZbPbdlAzsxLKj+DXL3pejMuu5FjTT0sG+VQ65eObOSOqaDhQI9tsFOpvxsOJpzeVPFcsq2hRwc0odokXshdbps5J7zrU83zvsy6PgnpzixHiEoc2ZI/J5rhu5JRLrQ+cnsjOub6ZiHrJdQa3fXWVa2TnrcejcuOZ0cjyJd5tgV5Ilhb8/lRTRocdBrESWpONLWobKTsys6sC7+NdYWrZzk+CbqIiC81TW1Lj8dryulnPSGh8Ug1tWQLxcfmIj6DJXnYHuKd9Jm2OMnlJFgzHmxT5HcDXXYt/dHtT7aO2U8da1TH3c2zGhsN+yXwuZuH/dyZ3ajDfr1GoUsG0kOeOXUthgU5YugDgl4hwLZzTbX4ce7jHpLBaGNLxo7ANRyMRBwqtYaw1G64HHQfDzjaklB9dKzJzrHua2zP9zW+frfE0oQTGS40UprafURQzVvSaBFyzTob6EtY9YmEfWWo+T70xB9qkw2te6aCT9yQcFHXgIOb7bjXTWiPHtVom08l4Fuzac174gQ38SGe8fqJ45CChm7+GN7eJA2Oht/eYjKd9ZR7LNERDp3NXW+0ONUf1LiDGjPov+8M1h6JjAKHvHDKdnDAZa1D41QTQTcBTCXgKSrdQv1BlcctuxsKvNumsh5qOvCgbABjhaepyxpxOjBKHHRDwLdz9npYTQ+4q/bWwNhCbyq+a/7BhmxrhN7rFewd2Bt6jXN4izwcGvLwtVdzCn2gnwFX2HnR3wuPYpMXzooQl8pthQHOlgcsUqhZ39AStDnQAefiuln73bzFq2brPQGaMNrOj9eysDxKK+50jUOfJwjulap+2Fu1nl/09LaX97ZlFNDLWidvezM81uKeu+Hzvul1d88aqGOMZ0z3RcPlNH6/5uOziZmqCH3IbZMXlbYdOA8cSeWgixj2JG/4euk3An3x+gyx0KQXweV9+nTyPkxSRuIwCfiZFyJl3C1nuZu+nRlrf+ZumM6ygufz2NgPNOcjj2LeH/KQRNtXRMJC54p1YEonioBlkQlEUhlaqaKr0l+eUdTq78yU8h+nk+efr2/f/SitVQv8cJ7ef5VQBbddWRQUF1OhfUU7gqsQuMWqspIkkV2x65/G+zwSnRm9ms+DMxPiO6PrO+BgQudukjH6iu9r46yjm8jm26lxNgbQWAiLP8d//xsO7a5J5g0AAA==
In Streamer.bot in select the hamburger ☰ menu in the top left and select Import.
Copy the Import Code (at top of this page) and paste it into the Import String box.
In the Action you can see the comments read:
“Set the full path, including the exe to TwitchSpeaker in the argument below”
Open a Window Browser and navigate to where twitchSpeaker is installed. Once there click in the top location bar and copy the path and the double-click the “Set argument” sub-action highlighted below
Next, paste the location of TwitchSpeaker that you just copied into the Value filed. Be sure to add \twitchspeaker.exe to the end. It should end up being something like:
C:\Streaming\Apps\TwitchSpeaker\twitchspeaker.exe
Tips
This is very handy when being used with the sb-init extension by Krayn_ that auto runs actions when launching Streamer.bot
