Kill Bets
Let your viewers guess how many times you die before you start your run! Or let them guess how many kills you achieve in the next round? It’s up to you! Guessing the correct kill might give the chance to win many points, but multiple winners, share the pot!
- KillBets.sb (26.8 KB)
SB alpha 1.x only!
Setup
Run the
TestTrigger to open up the GUI.
- Edit the settings to fit your needs.
- Enable all commands in the commands tab if needed.
- Enable
Free Modein theGametab if you don’t want to use points.
Available commands.
| Command | Description | Info |
| !OpenKillBets | Opens a round of guessing kills. | Supports multiple platforms (Twitch, Trovo, YouTube, Kick) |
| !CloseKillBets | Closing the round of guessing kills. | |
| !KillBet >KillGuess< >BetPoints< | Guess the kill count and risk points. | Only one guess per user |
| !ShowAllKillBets | Show a list of all kill guesses. | |
| !KillResult >userName< >KillGuess< | Award the winner(s) and announce the correct kill count. | Multiple winners possible, comma-separated |
Changelogs
v1
- Initial release.
