Follow Age Based Discord Link Command
These actions will only send discord links via command when the user of the command has met a certain follow age requirement.
There are two versions of the action, one that whispers the user of the command, and one that sends the message in chat. Import one or both of them. Both actions have the !discord command trigger disabled by default – if you import both, please right click and enable the !discord command trigger for the action you intend to use.
You must be logged in on Twitch in the platforms tab in Streamerbot.
Both actions are set require a 30 day follow age by default, but you can adjust the amount by double-clicking the if/else section and typing the desired value.
You may double click and adjust the message that will be sent.
For the chat message version, this will be located in the twitch message subaction.
For the whisper version, this will be located in the set global subaction.
Whisper version also requires a bot account to be logged in.
Made this mostly for Chloexhazard who asked about it on YouTube :slight_smile:
