Figuring out C# abilitites... graphics?
I’m a bit confused about what C# code through streamer.bot is capable of. I’m a Unity programmer and could make all sorts of simple games with C#. What I’m not understanding is how to get streamer.bot C# commands to interact with a game I make, and run it through streamer.bot. Is that even possible?
For example… could it run c# code that executes a program that draws some graphics? And then I could capture the output of that program via OBS? Everything I’m seeing so far looks like streamer.bot is driving “graphics” by toggling a bunch of OBS scenes and such. This seems reeeeeally convoluted and fussy to work with though.
Arf!! Now that’s a familiar profile I haven’t seen in a while. Hiya TK hope all is well!!
So I did read what you wrote on your post. Here’s my experience so far. SB is best used in conjunction with OBS when you do the animation within OBS such as source / scene / filters On and OFF with timing delays.
What you’re describing is something that is possible on paper but executing it will not work at all with SB.
This is because SB isn’t designed to be a game engine even though it can do c# and using C# you can execute to draw windows but SB will not be able to produce that.
That is why it is best used as a bridge between SB and OBS.
The reason I say this is because not long ago I built a fully working Ocarina similar what you would see in Legend of Zelda and it works exactly as you would see in the video game. But in order for me to accomplish all of it I had to DL, create and modify animations with delay timings in SB and use C# mainly for insuring who claims the ocarina and when the person that is playing the ocarina cannot be interrupted. And when said person plays the correct sequence of the ocarina it plays back the correct song with the music sheet and all the visual graphics for that song.
I hope this helps. I am going to be working on another Twitch mini game.
