Enhanced magic 8-ball
A Magic 8-Ball that has a few extra features, such as cursed answer tiers, the inclusion of custom emotes, a “lie” function, and the ability to “whisper” to the user who redeemed the command in the chat!
magic 8 ball.sb (9.7 KB)
  • Magic 8-ball Docs
    (Links to a Mega page for the download, as there are a few too many docs to upload here. please let me know if the link breaks!)
Steps for File Installation
-download the resources from the link above
-copy these files to a folder in your Documents library, and ensure the folder is named “Magic 8-Ball Docs”.
-when finished, go to each tier and click on the Read Random Line action. ensure that each action reads from the appropriate file.
Tier answer and Emotes
Post Effects
Not doing this will cause the ball to break.
You can customize any of the answers and emotes for the responses through the files and the timer delays in the sub-actions if you feel they are too long/short.
Command Description
!8ball Test command. Bypasses the need for input and runs command normally. Can be used to debug or as a normal standalone command.
Help with this bot came from Geefbird and his community!
This is my first creation for Streamer.Bot. As such, any constructive critique is appreciated!
Version 1
-Initial creation
