Streamer.bot Channel Point Moderation
This repository provides a customizable moderation script for Twitch Channel Point redemptions using Streamer.bot. The script helps manage excessive redemptions by implementing cooldowns, issuing warnings, and applying timeouts when necessary.
See the GitHub
Files Included
moderation.cs: The C# script that handles the moderation logic.channel point redemption moderation.sb: An importable Streamer.bot action file for easy integration.
Features
- Per-User Cooldown Tracking: Maintains individual cooldowns to prevent abuse.
- Customizable Settings: Easily adjustable parameters for max redemptions, cooldown window, and timeout duration.
- Moderator & VIP Exemptions: Configurable options to exclude moderators and VIPs from moderation.
- Two-Level Warning System: Sends a chat warning on the first offense and applies a timeout on the second.
- Non-Persistent Data: Resets all tracking data upon Streamer.bot restart to ensure fresh moderation.
channel point redemption moderation.sb (5.1 KB)
- Import the Action: Open Streamer.bot and select “Import” to import the
channel point redemption moderation.sbfile.
- Just drag and drop the file into the import field and click Import.
Configure Arguments:
MaxRedemptions: Maximum number of redemptions allowed per user within the specified time window (default: 5).WindowSeconds: Time window in seconds for tracking redemptions (default: 600 seconds or 10 minutes).CheckIfMod: Set totrueto skip moderation for moderators (default:true).CheckIfVip: Set totrueto skip moderation for VIPs (default:true).TimeoutSeconds: Duration of the timeout in seconds when a user exceeds the redemption limit (default: 120 seconds).TimeoutReason: Reason displayed for the timeout (default: “Spamming Channel Redemptions”).
Upon setting up, the script will automatically monitor Channel Point redemptions. It will:
- Track individual user redemptions.
- Issue a chat warning if a user exceeds the redemption limit.
- Apply a timeout if the user exceeds the limit again within the same time window.
License
This project is licensed under the MIT License.
Note: I’ve tested this with 0.2.8 and 1.0.0 - works with both.
