Auto clip scanner url
Hey, im using the Auto Twitch Clip Scanner and got some problems with the link.
I send it via Webhook to my Discord Server, but i got no image preview of thr clip.
Also i would like to have the profil picture of the clip creatot for the post.
Anybody knows how to help?
Add a delay of around 5 to 10 seconds before sending it via Discord Webhook, this will most likely make it so it loads the clip image fine.
As for the profile picture use the “Twitch > Users > Add User Info for target” subaction and select Variable then write clipCreatorUserName into the field. Then put that subaction before the webhook as well or even before the delay. Then you can use the %targetUserProfileImageUrl% in the Webhook as profile image
The issue I am having is when it posts the link to my discord the web link doesn’t link to the clip it says there was an error and asks me to look at documentation
never mind, I have figured out what was wrong, it was the embedded url not the clip url that was being posted
