Among Us Ban (Animation)
Some one in chat seem sus? Need to call an emergency mod meeting? Want to eject that impostor? Well now you can with the Among Us Ban Alert for Streamer.bot!
Source Copy: OBS Plugin
Among Us Ban: Resources (32.6 KB)
Streamer.bot
In Streamer.bot click the Import button in the top menu. Drag the .sb file into the into the Import Pane:
Among_Us_Ban_Animation_GoWMan.sb (1.2 KB)
OBS Studio
With Source Copy installed, go to Tools > Source Copy > Load Scene and select Among Us Ban.json.
Double click on the Play Sound Subaction and make sure it points to the eject_amongus.mp3 file.
Double click on the Obs Set Browser Source Url Subaction and make sure that it points to the index.html file in \Browser Sources\among-uspure-css.
Do NOT remove the ?user=%user% from the end of the Obs Set Browser Source Url Subaction or it will NOT work.
Do NOT check Local File in the OBS Browser Source.
%user% will only be populated if Streamer.bot has seen the user. If you ban a random account that hasn’t been in your stream while using Streamer.bot it will only display %user% instead of populating with the username.
