Walkon Sounds (aka Sub Sounds)
This simple set of actions allows you to have a custom entrance sound for each of your regulars.
walkonSoundsByGeocym(for_Streamer.bot_v0.2.2-earlier).sb (2.2 KB)
walkonSoundsByGeocym(for_Streamer.bot_v0.2.3-newer).sb (2.5 KB)
This setup allows an easy way to accomplish this without needing any complicated setup or maintenance.
Copy the text from the code box below into the Import box in Streamer.bot to add these to your action library:
The first thing you will want to do is set the folder path that will contain all of the subfolders. There will ultimately be one subfolder per user that you want to have a custom sound. Streamer.bot will randomly select a sound from this folder when a username matches
To set the path, open up the Set argument sub-action in each of the actions
Change the Value to match your setup
You will also need to create a folder named Generic inside your main "walkOns"
This folder will be used for any username that does not match any other folder. You can leave this empty if you do not want a sound for everyone
With this complete, set the Create Regular action to either a chat command or point redeem to allow your users to register.
If you are using Channel point option, you can enable the User Input Required if you want, that way users can speficy the sound they want in the message
The only thing this action does is create a subfolder with the same username as the person redeeming the reward, so you can create the folders manually if you wish.
All folders should be lowercase
You can set this up so that mods can enter a command followed by a username, to do this you will need to add a Get Info from Target subaction as the first line of the Create Regular action and adjust line 11 in the C# to read “targetUserName” instead of “userName”
Finally the Walk on Sounds action should be assigned to the First Words event in Settings
