Search Urban Dictionary for a Specific Word, or leave it to fate and pull something Random.
UrbanDictionaryApi.sb (2.6 KB)
Warning Use this at your own risk, They are no filters based in this so the output could be anything.
The References should import but if not you will need to add the following -
System.Core.dll
System.dll
You will need to make sure the !urban command is enabled. As commands are disabled by default.
You can choose how you want to display the results, the code will return the following arguments.
urbanDefinition
urbanWord
urbanAuthor
urbanLink
urbanExample
Example Usage
!urban This will return a random word.
!urban <word/phrase> This will return the defintion of the searched input.
