Get info about your Bits Leaderboard on Twitch via their API, whether just for the top 3 or top 100 users of all time, or a certain period.
Twitch_Bits_Get_TopX_by_pwnyy.sb (6.8 KB)
In Streamer.bot click the Import button in the top menu. Drag the .sb file into the Import String field. This will give you an action called [Bits] Get TopX (max100).
| Argument Name | Value | Description |
| topAmount | non-decimal number | How many users from the leaderboard you want to get. Min. 1, Max. 100 |
| period | string/text | Period of time that will be checked from current date. Valid Values: day, week, month, year, all |
| noUserText | string/text | Text which will be shown if no user is in that period |
| rankFormat | string/text | How each singular rank text will look like. User %rankPosition%, %rankUser% or %rankScore% in it. |
You can use the action as is, or in combination with a command or as a Run Action subaction.
Generated Arguments
| bitsPeriodStarted | DateTime | Start date of the period checked. Will be “/” if period was set to all |
| bitsPeriodEnded | True/False | End date of the period checked. Will be “/” if period was set to all |
| bitsTotalUsers | int number | Amount of users in the leaderboard |
| topBitsUsers | string/text | Text displaying the leaderboard |
| topBitsUsersObs | string/text | Text displaying the leaderboard for OBS text source |
| topBitsUsersFile | string/text | Text displaying the leaderboard for Write to File |
| topBitsUsersDict | Dictionary<string,long> | Dictionary with userId’s and scores of leaderboard |
| bitsTotal | long number | Total amount of bits spend by the leaderboard |
| includeBotAccount | True/False | Whether the bot account is included |
| bitRankUserId# | string/text | Twitch User Id. # is rank, starting at 1. |
| bitRankUserName# | string/text | Twitch Login name. # is rank, starting at 1. |
| bitRankUser# | string/text | Twitch Display Name. # is rank, starting at 1. |
| bitRankScore# | long number | Score/Amount of bits spend. # is rank, starting at 1. |
Version 1
- Singular Action with defining topAmount, period, noUserText, rankFormat
Version 2
- Adding topBitsUsersObs and topBitsUsersFile arguments
