chlu
December 6, 2023, 10:09am
1
Hello together
I’am strugling with the following extension:
Show a progress bar on screen with a goal that you setup.
[175262370-c61aca47-2e0d-4595-9c21-c812cff7ba1b]
This extension is outdated and currently being updated to work with websocket 5.x
TlM0RR+LCAAAAAAABADtfdlSY0ma5v2Y9TvQYZ1mVd3lWb4ed0+zuQAyABEEGawCNWVpvh1JgbbSAgFt9RrzHGN9PVfzKPMk8/uRBNo5EoJQZWZaEkGcxZfP///7l+PLf/3L/9ja+nAX2p1qs/Hhpy36l+xCw9QD/OvDebXV2frSbpbbodPZ2jHtrU63HUz9Yy3UQ6Pb2YJ/+IettNnewj+SH/WH/uvGdaG4DpTwn/HfW1v/1f8LblV9LFcHHZxPNbIpUYh7HZAxniKfGE2s0A…
First: The Websocket Connection is made a reconnect, when i’am try to initial. So the needed Szene, will not be generate in OBS
Additionally it would be nice, when the bar can be set up, also for other provider, like ko-Fi or Tipee…
OBS Version: 30.0
For example, when i try the Follow Bar, or the Sub bar, everything ois wokring for the initialisation… ( Quick Goal Progress Bar ( Followers / Subscribers ) )
Thanks for help…
chlu
Give me a bit to update it, it was still set for the 4.9 websocket version.
will see about others donations providers too
I tried to configure it here but I couldn’t, it didn’t work properly, it only creates the text and I can’t change anything.
