When creating a new topic you’ll have the template directly available to edit. Please use it. We aim for a consistent user experience across all extensions. Users should be able to easily locate the file and installation instructions in the same place, regardless of the extension they are exploring.
Do not include this wrapper in your post.
Please avoid using single # headers. Instead, utilize proper header hierarchy by employing ## for main headers and ### for sub-headers. This approach ensures that your headers will be displayed correctly in the table of contents.
The quotations can/should be deleted as they are only for your information. Of course, you are free to use quotations where you see fit.
Please also add the table of contents to your submission. You can do this in the editor menu by clicking on the cogwheel icon and click on “Insert table of contents”. This will add <div data-theme-toc="true"> </div> to the bottom of your topic. When you copy this template it should already be included at the bottom.
This serves as a submission template for when you submit your extension to the wiki. Even if you opt not to use the template, adhere to the prescribed layout order. Our intention is to provide users and reviewers with a clear understanding of the location of each element within every available extension.
Incorporate a YouTube link following the format demonstrated in the RAW. The embedded video will be visible for public or unlisted videos; therefore, ensure that your video’s privacy settings fall under either of these categories.
Please use the file upload feature in the editor menu, to upload your export file. The file should have the
.sbextension. When uploading a file it will automatically create a hyperlink and will add the filesize information.
- example.sb (46 Bytes)
For your extension to function effectively, provide hyperlinks to essential resources or upload them. Please use clear titles that are easily comprehensible to users. Follow the hyperlink format below as seen in the RAW or use the hyperlink button in the editor menu.
- File 1 (46 Bytes)
- External File 1
Always describe first how to import the .sb file into Streamer.bot
Now describe the remaining installation steps for your extension.
First Step
Describe the step and add screenshots if needed.
- This is the first thing you do.
- This is the second thing you do.
Second Step
Describe the next step
Detail the configurations and adjustments available within your extension. This includes all customizable elements that users can modify according to their preferences. Ensure that these options are not embedded within your C# code; instead, they should be directly accessible within the action, allowing users to easily make edits.
Action 1 Configurations
Example text.
Action 2 Configurations
Example text.
Display the available commands if your action uses them.
| !command1 | Does things. |
| !command2 | Does other things. |
| !command3 | Does even more things. |
Add other contributors’ main streaming platform (Twitch, YouTube) below as a hyperlink, so people can check them out.
The following “Testing Phase Log” section is only used during the testing phase. Once you are done with your testing phase you can copy the raw of your post and paste it as a submission and you can leave out the “Testing Phase Log” section altogether.
Version 1
- I added a thing
- I changed a thing
- I fixed a thing
Version 2
- I fixed something
Wrappers
This category is solely for your reference, providing information about the types of wrappers you can utilize to display important information within your post.
This is an info wrapper.
This is a success wrapper.
This is a warning wrapper.
This is a danger wrapper.
