Stream Elements One-Click Watchtime and Points Import
Did you recently switch from Stream Elements over to Streamer.bot? Maybe you’re running both because you’re afraid your viewers will lose their loyalty points and watch time? This extension allows you to transfer BOTH directly into Streamer.bot with the click of a button!
SE Auto Importer
This will work even on a BRAND NEW copy of Streamer.bot. It does NOT matter if they have visited your chat since you’ve started using Streamer.bot or not. This extension will automagically add them to your Twitch user list!!
Mustached_Maniac StreamElements Auto Importer.sb (9.2 KB)
Setting it Up:
In Streamer.bot click the Import button in the top menu. Drag the downloaded .sb file into the ‘Import String’ field and click Import. You will see 1 Action and ZERO Commands.
Running the Importer
Once imported, select the Stream Elements Auto Importer action, go to the Trigger box, Right-Click, and select Test Trigger.
The pop-up below will appear on your screen.
After typing a name for your points in the box (or leaving it blank) check Import Points, Import Watchtime, or both boxes and then press the big purple IMPORT NOW button.
If left empty, they will be stored under the name "points"
Be patient! As a reference, it took approximately 1.5 minutes to successfully go through 2100+ Stream Elements users during my testing.
CONGRATULATIONS!!
You did it! You should be greeted by a chat message saying how many users got points and/or watchtime added to them.
Verification
If you’d like to verify that it worked, you can click on the Variables tab in the top of Streamer.bot, then the Persisted User Globals tab. Select twitch from the drop-down menu and then select a random user from your list.
Special Note
Paranoid, or notice that somebody is missing points? Feel free to run the action as many times as you’d like. If there are no changes to points/watchtime you will get a message like the one below. If there is an increase in either, it will only add the difference to the existing points/watchtime balance.
