Raid Suggestion Channel Point Redeem
Let viewers redeem channel points to suggest a raid target for the end of the stream. Broadcaster can pick a random target from the pool of suggestions or select the most voted suggestion.
twitchRaidSuggestionChannelPointReward-0.1.0.sb (exported for Streamer.bot v0.2.0+) (16.1 KB)
Steps to setup
- Create a channel point reward and enable
User Input Required. Feel free to configure the rest how you see fit. Link this reward to the actionRaid Suggestion Channel Point Redeem - Link the action
Raid Suggestion Completedto the Twitch EventPlatforms > Twitch > Events > Raid > Send Raid - Make sure to enable commands
!randomraid,!refundraid, and!votedraid, as imported commands are disabled by default. Edit permissions how you see fit
