OBS WS v4.9.x
OBS WS v5.x
Show a progress bar on screen with a goal that you setup.
quick-goal-progress-bar_WSv4.9.x.sb (31.4 KB)
quickGoalProgressBar_WS_v5.x.sb (34.1 KB)
Required OBS plugins
- OBS Shaderfilter Plugin
- OBS Websocket-compat Plugin for OBS v28+ (Optional: Only use if using the WSv4.9.x extension)
- In the actions:
Follower Goal 1st : Set !createfollowgoal&Subs Goal 1st : Set !createsubgoal, set the directory of your OBS
- Use
!createFollowGoalto add a new nested scene with the Follow Goal Bar
- Set your follower goal using
!setFollowGoalin chat
- Use
!createSubGoalto add a new nested scene with the Subscriber Goal Bar
- Set your subscriber Goal Number using
!setSubGoalin chat
