Prediction Creation And Management Commands
Twitch Prediction Commands
Create and manage predictions using simple chat commands. It’s more convenient than having to use twitch’s UI, and it also allows moderators on mobile to help with predictions.
Create Prediction:
!prediction <title> | <option1> | <option2> | etc...
Resolve Prediction:
!prediction resolve <winning_option>
Lock Prediction:
!prediction lock
Cancel Prediction:
!prediction cancel
prediction_command.sb (3.6 KB)
Setup:
  1. Download the Import File.
  2. In Streamer.bot in select Import from the top left.
  3. Drag and Drop the Import File into the the Import String box.
  4. Enable the !prediction command on the Commands tab
You can set the prediction’s duration by changing this value in the sub-actions section
Curious how this any different from the current extension Dynamic Twitch Predictions
If they are no differences then, this wont be approved,
We want to avoid having exact matches
If they is a difference that im missing Please let me know and we can check them out :slight_smile:
