I recently imported this extension:
The code for Check URL appears to not be working. I have tested the other elements and all appear to function correctly, however the Check URL code does not seem to activate. I have attempted to insert simple "Hello World"s at certain points within the code to find a specific fail point (before string permitUser, after string permitUser, and after the if!allowed timeout chain. I consulted a friend who is more familiar with C# code than I am, and neither of us was able to figure out what was wrong. He believes it may be a syntax error.
I also tried replacing the Check URL code with this piece of code:
using System.Text.RegularExpressions;
using System.Collections.Generic;
CPH.SendMessage("Hello world!");
and it functioned properly, so the issue appears to be with the current Check URL code and not the Execute Code function itself. Thanks!
EDIT:
The solution has been found.
In line 41 of the Check URL script, CPH.TimeoutUser(args["user"].ToString(), 15); needs to be CPH.TwitchTimeoutUser(args["user"].ToString(), 15);
