This is some example code I threw together to use the cloud API for LIFX smart bulbs - pretty much lets a chat command or point redeem choose a color to change the light to, accepts colour names or hex values
Code
using System;
using System.Net;
using Newtonsoft.Json.Linq;
using System.IO;
// your main code goes here
// Choose a random colour for the light
//var random = new Random();
//var color = String.Format("#{0:X6}", random.Next(0x1000000)); // = "#A197B9"
var color = CPH.GetGlobalVar<string>("bulbcolor",true);
var url = "https://api.lifx.com/v1/lights/all/state";
var httpRequest = (HttpWebRequest)WebRequest.Create(url);
httpRequest.Method = "PUT";
httpRequest.Headers["Authorization"] = "Bearer TOKEN REDACTED";
httpRequest.ContentType = "application/x-www-form-urlencoded";
var data = "color="+color;
//var data = "color=#522AC0";
using (var streamWriter = new StreamWriter(httpRequest.GetRequestStream()))
streamWriter.Write(data);
var httpResponse = (HttpWebResponse)httpRequest.GetResponse();
using (var streamReader = new StreamReader(httpResponse.GetResponseStream()))
var result = streamReader.ReadToEnd();
Console.WriteLine(httpResponse.StatusCode);
You can send animations too, the documentation is up on List Lights
