Followage (with targets and fail)
TlM0RR+LCAAAAAAABADtV8Fu3DYQvRfoPwgL+BYWJEVSZG/uwa2Booc0PRU9DMnhWoBW2lJSbCPIv5eSvLZWXqe7ycJJgZ4kcYbk8PHNm9GH77/LstV7jG3Z1KsfM/5mHKhhg+lrtZo+wXXJ3KaRP4fvLPswPZKp9IMfIvi8yHPifIFE5CCIVt4QCRqNEcpwNNNa46S/e+yH9eu+qp5GsQZb4bBeF3ucjd+5qvd4FZvNL2XbNfE+uQSo2pnPLuCrpqqa28s1znZbx6bfDsafoC3dzADVLdy3b/v6+XoRat9sLsdzP7e6pnZ9jFh3z23PsNrDa3Rpmz46fHe/xUfEH23vIZYDDE/oP5omqHVhjZaGkRy4IILmnhgLjgiUiisRbGB2MfEWy/XNECr9ge5buikGuRjeIbZ3P5+6oym+2uPdsMvT6Mc3L2GwO+dvDxcX4fa63vbdIvRmixEeLoEukar6QzBNF3A9gmULJiQCEstDgkgaSWwhLAkFh+AZl0VYghX7+nqzQV9Ch9X9wYNC6DA+coMtEEpsuHwK4QCEyeHtv28yrrO3ET1Ih5wHpRkQ7kWig2E0nZVSYpzHxAbvVFGcSgfGz8oHdgwfOrwbQlpdhDGD+xbjRXYDbWYR62waLOt1eovZg0/K8l+ben2xON42YsCUnP7SuaYfU5QdQo6j9ToRgHhlB80KNGlWUERp7VAyVhjpTkburMCJz0mkPWw+kU3q9GwShZOeUUEoFQmxYIBYaZAUjhlljLJB4H87m3Kl0HmTChcFmU5YOGKt8ERqRjEo9Gjys2XTEupjKJEfQ4m9+pK/XF86iGvs/kipdrjS5FQx6lMp59YTAUOlQaVT4QGVC+ktCnpypWHnw4LPsNi9/rUsxD8PG4zVeGZyKUdg26KfWSfjDtRlg3Ma9V+jwbmCsvqWm5ydoL+7Kdts4FjmG2yzuuke1Dy7sLEB76AdKXiEjB9M2RC8AhYkAQM8FUCeZBy8IsByz0IuUHP/dWWcviJPT2t4XoOnv2MVvmWe7onlQp3mYjmR9gWpBKED5IUl3DlGhEqIg9VAlAQGBWVMO/k1pfKolvz1WzAsKKR/Q04s06nCUJneisBJyltllaUJupNheyl3v7TC/N+AvUYDxqTMg/dAdMCk5iL1HNrlnHChC43aKydP/rs9awM2/5k5m5gPj8lzUuTZ1DRts0n6t/P/+A9uKKRsshEAAA==
followage_actions
This action has a few Get info/followage Sub actions you will need to check that these match. In FollowAge you need to get target info from input and Add follow age info from targetUser. Then FollowAgeSelf you need to Add follow age info from who redeemed
This will just need a !followage command tied to the FollowAge action.
This command is set up to allow an input after the command you will need to make sure the command location is set to start.
Example Use
This command has a slight bit more than the previous example, so a user can just do !followage to get their own follow age, however the user can now do targeted followages (as seen below) to get the followage of another user. It will also throw an error if the user does not follow the broadcaster.
