Create Simple Polls using this Extension!
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
To set this up you will need to create a command, tied to the action “Dynamic Poll”.
Remember because you want it to read input you will need to have the ‘Location’ set to ‘Start’
You can also control the Length, Bits Per Vote and Channel Points by adjusting the Set Arguments within the action.
| Argument | Description |
duration |
This is how long you want the poll to be in seconds. |
bitsPV |
This is how many bits you want viewers to be able to use to vote again. |
cpPV |
This is how many Channel Points you want viewers to be able to use to vote again. |
Remember Channel Points used in this way are non-refundable
so take care in the amount you use.
Example Use
TerrierDarts: Question|Option1|Option2|Option3|etc
TerrierDarts: !createpoll How Are You!?|Amazing|Terrible|The Best
C# Version
If you have an idea on how you would like to run a poll with set question and answers, you may wish to use this c# code.
using System;
using System.Collections.Generic;
// replace the text between the "'s with the poll question
var pollQuestion = "Which poll option is best?";
// these are your poll options, you can have upto 5, if you don't want 5, just delete the lines you don't want, so say
// you would like 2, delete Option 3, 4, and 5.
// and be sure to rename your options by changing the text inbetween the "'s
var pollOptions = new List<string>();
pollOptions.Add("Option 1");
pollOptions.Add("Option 2");
pollOptions.Add("Option 3");
pollOptions.Add("Option 4");
pollOptions.Add("Option 5");
// change the number below to alter the duration of the poll, it is in seconds
var duration = 60;
// the next two are options, leave them at 0 to disable them, or, set them to a value to enable them
var bitsPerVote = 0;
var channelPointsPerVote = 0;
CPH.TwitchPollCreate(pollQuestion, pollOptions, duration, bitsPerVote, channelPointsPerVote);
