Display Latest (Subs, Followers, etc.)
Easily show the latest sub / follow / raid / tip / cheers with this overlay and Streamer.bot.
To build up the URL, for the browser source, start with URL below (note the /? at the end is required):
https://vrflad.com/latest/?
Then you can add on the following options, each separated by &:
Config options
option description example
sub Latest Subscriber / Resub / Gifted Sub / Gift Bomb
follow Latest Follower
cheer Latest Cheer
raid Latest Raid
tip Latest Tip
lcheer Largest cheer
ltip Largest Tip
fontcol Font colour set to colour - using standard web names only fontcol=color
fontcode Font colour code, RRGGBB (without the #), 000000 being black and FFFFFF being white-space fontcode=RRGGBB
fontfam Font family that is present on the machine (if unsure, check the fonts control panel to see what you have available) fontfam=pristina
bold Set the font to bold
large Make the overlay ~60 pixels high rather than the default 40
xlarge Make the overlay ~80 pixels high rather than the default 40
middle Make the elements in the overlay align to the centre of the area they occupy.
Examples:
https://vrflad.com/latest/?follow&sub&cheer&xlarge
https://vrflad.com/latest/?follow&sub&cheer&raid&middle&large&fontcol=blue
https://vrflad.com/latest/?follow&sub&cheer&raid&fontfam=pristina&xlarge&bold&middle&fontcol=red
https://vrflad.com/latest/?tip&sub&cheer&xlarge&fontfam=Arial&middle&fontcol=grey
To use a different machine / port for Streamer.bot than the same machine default, then you can add onto the end of the URL: ?server=machine:port
Examples:
To connect to streamer bot on port 8081 rather than default 8080, whilst displaying subs,
https://vrflad.com/latest/?server=localhost:8081
To connect to streamer bot on a different machine on IP address 192.168.0.10 with default port 8080:
https://vrflad.com/latest/?server=192.168.0.10:8081
If you want a translated version of this, please do reach out and I can help get this set up and to link below:
French (Merci, LeBlux)
https://vrflad.com/latest/french.html?
Portuguese (Obrigado, LiveDoEdu)
https://vrflad.com/latest/portuguese.html?
Spanish (Gracias, DJ_Pole)
https://vrflad.com/latest/spanish.html?
