A handy Bot (or disruptive user) listing tool that allows you to create an editable list of names to ensure they are ignored for actions you choose. By simply adding a Run Action of the Ignore That Guy Checker at the beginning of any action, you can now safely eliminate all bot names from being able to trigger it!
Essentially, this is a quick method to ensure you can stop unwanted names from triggering things!
(not available yet)
Bot Eliminator.sb (9.4 KB)
- Official Documentation: Install Instructions
First Step
Describe the step and add screenshots if needed.
- Open the “Bot Eliminator” action and right click Test in the triggers and test the trigger.
- In the form that opens:
Enter Twitch usernames in the Twitch Handles box.
Enter YouTube usernames in the YouTube Handles box.
You can enter usernames:
One per line
Click Save to store your list.
Your global variables will now contain:
OSUP_Exclude_Twitch
OSUP_Exclude_YouTube
Second Step
Add the Checker
- Add a new action step.
- Use Run Action → Select:
Ignore That Guy Checker. - Ensure it is the first sub-action in the list.
| !ignore (user) | adds name to the list through chat message. |
OSUPhoenix
