Auto Launch Speaker.bot (or any program)
When starting Streamer.bot, this action checks to see if Speaker.bot is running and if not, automatically launches it.
While it is already set up for the speaker.bot.exe, it can somewhat easily be adapted for any program you want to be sure is running when launching Streamer.bot.
auto-launch-speakerbot.sb (2.4 KB)
In Streamer.bot click the Import button in the top menu. Drag the .sb file above into the Import String field.
Go to the newly imported Launch-Speaker.bot action and double-click the “Set argument” sub action to edit it. Paste the location of the speaker.bot.exe (along with the exe itself) into the “Value” field.
nate1280
