Using this Extension you will be able to add known bots to a group, this does not ban them however it allows you to exclude them from randomUser type events.
There is a setting if you want to you can save these names to a file, you will just need to make sure that the saveNames is set to True and you’ve entered the file path in savePath
After you’ve imported the code you will need enable the command [ !updateBotsList ] or create another, or even use another Trigger such as Timed Action.
This will automatically create the Group, but won’t set it as a Bots Group by default, to change it, just right click and set it to YES
