Create a 20 second instant replay with Streamer.bot.
OBS WS v4.9
- rewind-import.sb (2.2 KB)
Drag and Drop the Import File into the Import String.
You can follow Nutty’s video for setting up OBS at least with Nested scenes & Dynamic Delay Filter.
Whole effect takes about 8GB of your RAM, so be aware of that.
Also, make sure to check all Sub-Actions that they are pointing at your OBS scenes, filters and sound files.
I plan on making video showing how to set this up from the start to the end.
- rewind-effect.zip (705.2 KB)
To get timings right with my example action use these settings for Dynamic Delay plugin:
| Settings | Data |
| Duration: | 20s{.datatype} |
| Fast Forward: | 1000%{.datatype} |
| Fast Backward: | -1000%{.datatype} |
| Fast Forward OBS hotkey: | CTRL+NUM3{.datatype} |
| Fast Backwards OBS hotkey: | CTRL+NUM1{.datatype} |
